Televison & Video Logo
Claire Williams Posted on Aug 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Viore LCD26V37HA Won't Work With Cable
A couple years ago my father-in-law bought this nice HD TV as an anniversary present for his wife. It never worked with their standard cable box so it ended up sitting in the guest room, neglected, until my husband and I got involved. I even ordered an HD cable box hoping that would fix the problem, but nothing works. Plugging a coax cable direct from the wall to the TV won't work either. I've spent all day fiddling, googling the problem and chatting with Comcast's reps and I am about to just give up and throw the TV against the wall. Should I?
francoise cleofas
Level 3:
Genius:
  • Viore Master 2,432 Answers
  • Posted on Aug 16, 2012
francoise cleofas
Viore Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298426
Points
6852
Where did you hooked up the cable box, how about the settings in the tv did you checked?.
5 Related Answers
Anonymous
  • Posted on Jul 06, 2011
SOURCE: TV won't turn on.
I say press the input button until you see a picture!.
Anonymous
  • 4 Answers
  • Posted on Feb 14, 2009
SOURCE: No power to TV. Will not turn on.
I had the same problem... I fixed it by replacing 4 bad capacitors on the Power Module PCB.
Thanks,
[email protected]
Anonymous
  • 75 Answers
  • Posted on Jun 09, 2008
SOURCE: Actually it a lnt5271f, but...
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
A
Anonymous
  • Posted on Jul 15, 2008
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Aug 02, 2008
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
I stay with my wife for 21 years on her fathers poperty what rights have I
Are you or were you ever married?, If so get an attorney. If not read about common law.. If you lived in the same dwelling with your ex for more than seven years then you are entitled to more than you think. Sorry to hear good luck
hope this helps
tip
My father-in-law broke his him a couple of years ago and his son bought and...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jun 22, 2010 • Televison & Video
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
1helpful
2answers
What is the code for cable remote
Viore told me that they do not have a code that can be input into any remote. I have two Viore TV's... just bought my 2nd a few days ago. You will always have to use the Viore remote to power up or just turn off the cable instead. Not sure that turning off cable completely turns off the TV though.
Channels
they passed a law a couple years ago, see now you have to BUY cable... right now ur just gettin what ever the antenna on ur tv picks up. buy cable or dish or somethin and u get like 70-150 channels
Top Viore Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
