Microsoft Windows Vista Ultimate Edition Logo
ecburrola Posted on Aug 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to make a start up disk for a lenovo with vista home
Microsoft windows vista home basic.. cannot log on due to user profile dose not load
Brian Sullivan
Level 3:
  • Microsoft Master 27,725 Answers
  • Posted on Aug 15, 2012
Brian Sullivan
Microsoft Master
Level 3:
Answers
27725
Questions
Helped
5670261
Points
79191
Http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
$9.75
Click Here to Learn How to Create a System Repair Disc for Free
It turns out that Microsoft is going to let you create your own Windows 7 or Vista repair disc when Service Pack 1 comes out in a month or so. If you can't wait that long, the nice people over at Neosmart have created their own Windows 7 or Vista Repair Disc available for download. Update: it looks like the discs are no longer free.
The file is an ISO image file... if you are familiar then skip to the link, otherwise we've also got instructions on how to create a CD from the ISO file.
Burn Windows 7 or Vista Recovery Disc ISO to CD
You may already have a tool to do this such as Nero, but the best tool available for burning ISOs is ImgBurn, a freeware utility that does nothing else but burn ISO images, and it does it well.
Open up ImgBurn, and then click on the "Browse for a file" button, selecting the file you downloaded from Neosmart.
Put a blank CD into the drive, and then click the big Write button.
That's about all there is to it... you now have your very own Vista Recovery CD.
Download ImgBurn from imgburn.com
Download Windows 7 or Vista Recovery Disc from neosmart.net
Note that this download is no longer free
hope this helps
4 Related Answers
Anonymous
  • 264 Answers
  • Posted on Jul 10, 2008
SOURCE: running start up script
Click start - Run- Type "msconfig" without quotes.
Click the startup on top. Uncheck the startup script you mentioned. Save and restart and it should boo up fine.
Hope it helps. Kindly update me as well.
Regards
Sammy
ultimitloozr
  • 489 Answers
  • Posted on May 31, 2009
SOURCE: I WANT THE PRODUCT KEY OF WINDOWS VISTA HOME basic to start my computer
If you have a legitimate copy of Vista, the product key is located on a sticker attached to their funky packaging. If you bought a downloadable copy, you should have received a confirmation e-mail that contains your product key. Otherwise, you will need to contact Microsoft to have them help you straighen out the situation.
Anonymous
  • 144 Answers
  • Posted on Jul 13, 2010
SOURCE: cause of user profile not loading
The question is:
What causes a user profile not to be loaded in Windows domain based network?
the answer is:
there are probably 3 broad reasons for this,
1. the user corrupted their profile somehow, such as shutting down without logging off (hard power off)
2. the connection to the domain was lost ungracefully, and offline information was not copied entirely, causing a mismatch of some encrypted profile data, (effectingly corrupting again) and preventing the logon.
3. an unknown event took place between the last time the user sucessfully logged on, and this time where the profile is now not loading. this could be hardware related (faulty Hard disk), RAM parity errors( bad memory), a change to the user profile SID details on the domain controller or other domain change.
Usually the cause is not so much a problem, unless it consistantly reoccurs.
Fixing it however, in XP is fairly easy.
with an account with domain admin rights, just navigate to the UNC path "\\computername\c$\documents and settings" - note the name of the folder/user affected, and just .old their profile folder.
example, username is Philip. - you see in their c:\documents and settings\ folder the folder called Philip, rename it to philip.old or something else.
You have to ensure this is done while the user is logged off, as files in this folder will be in use otherwise. potentially useful to reboot the computer before navigating to the profile folder.
Anonymous
  • 846 Answers
  • Posted on Sep 30, 2010
SOURCE: download microsoft windows vista home basic full
Click "HERE"
Download and Install the uTorrent Client from http://www.utorrent.com/
  • Browse to a site that serves torrent files and peruse their list to find a file you want to download.
  • Click the link that provides you with the .torrent file. This file type will be recognized by uTorrent if you've set the option for it to do so. If it is not opened automatically by uTorrent, then save the .torrent file to your hard drive.
  • Run uTorrent and click "Add Torrent..." from the File menu. Select the .torrent file you saved in the previous step. The download item should appear in the main window. Once the program has found peers that are serving the file, it will begin downloading the file to your computer.
  • Ad
    Can't log on to my computer
    I could explain it simpler of you need but I think this site does a decent job :
    My "ACER" laptop has started to leave this msg on start-up (windows 7" "the user profile Service service failed the login user profile cannot be loaded" . My only option is then to shut it down. Windows...
    i try to give you the solution bat i cant because the windows words there in?when i press post solution fixya is tell me to Please use English characters only, so you can email my and i can send you the solution via email.. [email protected]... cheers..
    Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
    Please check following link from Mocrosoft knowledge base:
    Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
    http://support.microsoft.com/kb/947215
    PS: If it helps then please click on thumbs up.If you need more help then please let me know.
    When I try to log on I get a message that says, The User Profile Service service failed to log on. It also says , Profile can not be loaded. How do i fix this
    Sounds like your getting logged into a temporary profile. To fix this do the following
    • Click the Window Button
    • type regedit and press enter
    • Navigate to HKEY_Local_Machine\Software\Microsoft\Windows NT\CurrentVersion\Profile Lists"
    • Click on each folder that starts out "S-" and look at the value for "ProfileImagePath" that has your username in it.
    • Once you have found your SID, on the left side right click your SID(S-...) and add a .bak to it
    • Exit regedit and reboot the computer and try and log in
    • This should recreate your SID for your user
    If this is not the issue or you need further help please comment back.
    1helpful
    Buenas noches, apenas enciendo mi portatil dell 700m me pide clave de bios, la lleve a un tecnico y creo que no la trabajo bien y no la logro desbloquear, que puedo hacer?? soy de colombia y la verdad no...
    Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
    The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
    1. At the Windows logon screen, click Reset password.
    2. Insert the recovery diskette or USB key.
    3. Follow the instructions on-screen to create a new password.
    4. Log onto the account using your new password.
    new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
    Issue 3: Resolve Error: The User Profile Service Failed the Logon
    The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
    "Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
    Issue 4: If You do not have a Password Reset Disk
    If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
    Profile settings did not load correctly
    Try to create a new user account
    1) Click on Start
    2) Click on Control Panel
    3) Click on Classic View on the left hand side.
    4) Click on User Accounts
    5) Click on Manager Other Accounts
    6) Click on Create a New User Account
    7) Type in the name of the new Account and select the user as administrator
    8) Then click on Create Account.
    The Account would be created successfully.
    Log Off from your user account and login from the new user account that you have created.
    To get all the settings from your old user account to the new account copy all the items from c:\users\old user account name to c:\users\new user account name.
    1helpful
    User profile was not loaded correct
    Log in as an administrator. Take backup of data in User profile. Delete this profiel by going to control panel---System---advanced tab--User profiles. Then try log in with username.
    Can not login on normal mode and when i type in my password its says profile server not found and i have to do it on safe mode and i can not access my files,pictures or documents why is this.
    You need to create a new user profile in safe mode and then log into that profile in the normal mode. and for accessing your old files you need to follow the following path c:/documents and settings/user name
    and if you get an access denied error follow the following article
    http://support.microsoft.com/kb/810881
    Vista log in
    The user profile seems to have corrupted. The account that you log into is corrupt now may be due to incompatencies or incompatibility or may be a virus or a spyware. Alternatively, you can try logging to safe mode window. As you start the computer keep tapping the F8 key on your keyboard at the sametime. You would reach a screen to choose from different boot options. Select safe mode(you would have to use the arrow keys in your keyboard). Log in with the usual username and password. If it logs in, you might see a black window with large icons. Don't worry. Go go start, control panel, user accounts, and create a new account. So you can use the new account. Restart the computer and login to the new user account. You should be good. Make sure the account you create should be an administrator. Later if you want you can delete the user account that you have been using before. You can delete it from safe mode again by going to control panel, user accounts.
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
