Will it only work on certain TV's?
SOURCE: How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
SOURCE: dvd player will not open
look at the bottom of the unit and see if it has a slot to put in a pin and manually open the drive, most of them have some way to do this look for a slot or pin hole to push the release, sometimes they do this because someone pushes the drawer closed instead of using the button or remote, you will have to open it to reset it if that is the case you might have to easily force it open.
SOURCE: Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
SOURCE: Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
SOURCE: how to turn off progressive scan on Allegro Dvd Player
"With the TV and DVD player on press the "STOP" button on the remote for more than five seconds or until the start-up screen appears."
I got this from the following link... http://www.techlore.com/forum/thread/17900/Allegro-DVD-STUCK-in-Progressive-Scan-and-I-need-it-UNSTUCK--PLEASE-HELP-/
