20 Most Recent TruTech TT1620 DVD Recorder Questions & Answers
2answers
Getting it plugged in right to work with tv set
you dont put it on channel 3 like a vcr. you put it on video input like you would when playing a game.
5/6/2014 4:40:14 PM • TruTech TT1620... • Answered on May 06, 2014
Remote code
this question and soultion may help answer this issue. This question ahttp://answers.yahoo.com/question/index?qid=20070114135510AA7UNc0It looks like you may have to buy a new recorder altogether.
6/19/2013 4:44:33 PM • TruTech TT1620... • Answered on Jun 19, 2013
Trutech tt 1620 dvd recorder
can i get manual trutech ttt1620 can download one
8/22/2012 6:27:00 AM • TruTech TT1620... • Answered on Aug 22, 2012
The unit turns itself on
This is a shut down due to an error in the system and is related to the malfunction of the main drives or the optical units.
You need to check the loading and drive sections, check the power to the main board/ processing section. Some times a fault in the mother board can result in such a shut down and will require a flow chart check up.
Take consensus without tampering.
9/8/2011 10:53:39 AM • TruTech TT1620... • Answered on Sep 08, 2011
I have a TT1620 but
Out of the several hundred reviews I've found on this product, exactly two gave it a passing grade. The vast majority of complaints were the flaky/useless tuner, and the flaky/useless DVD writer. The writer issue seems to be mitigated somewhat by using Memorex blank media. The tuner issue seems to be a design flaw. The only work around I've found has been to use the other inputs and use a cable or satellite box for tuning.
Sorry, but it sounds like you got one of the many duds. Wish I could offer more encouragement.
7/6/2011 7:26:27 PM • TruTech TT1620... • Answered on Jul 06, 2011
2answers
All I want is the manual for tt1620 DVD Recorder
Click below :-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
and you can download the manual by entering the code in the box provided on the page. I know it says it's the DVR-1600, but it's the same machine.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/16/2011 7:45:38 PM • TruTech TT1620... • Answered on Jun 16, 2011
Cd tray will not open
This is not a solution but...I started to have this happen to me and I found a work around. reapeatedly try - many many times and when you DO get it open, put a disc in and see if it wil open after that. Make it a disc you can afford to never see again, just in case. On my 1620, as long as a disc in is in the machine, it will open. If you close the door when it is empty, it will be VERY difficult, but not impossible.
last resort, open the machine and slip a disc in, then try.if possible.Unplug it first, of course.
Ps
My machine worked great for 2 years before this started to happen.
3/18/2011 2:59:21 AM • TruTech TT1620... • Answered on Mar 18, 2011
I need a remote control and user manual for this
Try www.trutech.com for customer support.
1/1/2011 5:34:10 AM • TruTech TT1620... • Answered on Jan 01, 2011
My DVD recorder is telling
This means the material you are trying to record is copywrite protected and can't be recorded. This can come from other DVD's or even certain brodcast programs are copywrited and therfore can't be recorded. I Have heard there ia abox you can hook to the DVD so it will remove thes copywrites but I don't know if they are still for sale. I hear someone tell me that he got his at Best Buy but that has been a few years back. If you have a computer and can go online, there is a program called DVD Fab decrypter that can remove the copywrites to most DVD's and you can make a copy on your computer to watch in your DVD. Just look up the DVD Fab Decrypter and check out their site. There is a cost for this program but I thought it was well worth it, I have made personal copies of many movies using this prgram.
11/14/2010 8:22:58 AM • TruTech TT1620... • Answered on Nov 14, 2010
I bought this unit as
this is happening because the laser (lens) of the player is not sharp anymore. It takes a very sharp laser (lens) to record a DVD disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one. Or, to better clean the lens, loose/unscrew the player's cover, use a cotton board to clean the surface of the lens completely. This will help to wipe off dust on the laser (lens)
Good luck.
10/16/2010 2:40:05 AM • TruTech TT1620... • Answered on Oct 16, 2010
Do I need a special
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
10/2/2010 7:43:28 PM • TruTech TT1620... • Answered on Oct 02, 2010
I lost my remote and need to get a new one.
Try website like Remotes.com to buy an exact or colse to the original remote.
8/14/2010 5:38:06 PM • TruTech TT1620... • Answered on Aug 14, 2010
I CANT FIND TruTech TT1620 DVD Recorder CODES
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for TruTech DVD recorders in the One For All URC-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code Entry
One For All URC-3021 Reassign Key
5/30/2010 7:19:29 AM • TruTech TT1620... • Answered on May 30, 2010
I have the trutech dvd/vcr
FINALIZE THE DISC
3/16/2010 1:06:55 AM • TruTech TT1620... • Answered on Mar 16, 2010
TruTech TT1620 DVD Recorder Logo
63 questions posted
Top TruTech Televison & Video Experts
ExpressFiX
ExpressFiX
Marvin
Marvin
matt martin
matt martin
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TruTech Televison & Video
Most Popular Question
bought unit as
  • Televison & Video
