SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
SOURCE: 2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
SOURCE: Describe your Frigidaire FSC23R5DSB Side by Side
That is the first sign of not defrosting. Look into the rear panel in back of freezer and see if frost is forming on that back panel. If yes then you will need to unplug and remove that panel to inspect the defrost heater and defrost thermostat. If they check out then we need to inspect both sides of the mother control board for burn marks or signs of heat damage. The 1467835 Control Board is located on the back and enclosed inside a plastic housing. The same circuit board also list as part number 241511101 Check the freezer first to see if the defrost heater may be bad. Need an OHM meter and take one wire off of one end to test. I will walk you through this if you want, Sea Breeze
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
