How do I remove offline mode when my sim card is not inserted?
Most of this problem comes due to failure of Connection between the Sim card and the Sim card slot.Since, there is no separate Sim card IC the only thing you need to check is to clean the Sim card connector or sometimes the connector might bend.Moreover, you can at least insert other Sim card and try.Otherwise, contact nearest mobile repairing shop.Good luck.Thanks for visiting fixya
SOURCE: Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
SOURCE: my phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
SOURCE: Changed nokia e66 housing.. and now offline
I have the same problem..i replaced the sim band and the problem still persist.. what to do ? :' and my wifi dont detect any network :' wtf?:((
