20 Most Recent
Nokia E Series E7-00 Touch Smartphone- 16gb - Gsm Unlocked - Gps-wifi-hdmi Questions & Answers
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the
profile from offline,when i try to change the profile from offline to
others it hang and restarts showing the offline while sim inserted!tried
with different sim but no use.
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
Help me Forget nokia 1680c 2 .how fo do it? please
What do you mean by a 'restriction code'? If it is your password you might have to do a 'factory reset' on your phone.
If it has been locked with the IMEI code you will need to contact your network supplier to get them to unlock the handset.
Nokia N95. What would be the pairing code from a Nokia N95 to a generic pair of Bluetooth headphones please?
My first thought was that the phones doesn't have Bluetooth, but it does.
https://www.gsmarena.com/nokia_n95-1716.php
The key to the code would depend on the make and model of the headphones. Likely to the '0000' or '1111' or similar.
The most common PIN is four zeroes in a row, 0000. Two others you may encounter on some devices are 1111 and 1234. Try entering those when you're prompted for a PIN, starting with 0000, and most of the time, the pairing finishes successfully. If issue persist, proceed with these steps.
Feb 1, 2021
Asking Pin for Bluetooth Earbuds - Microsoft Community
Microsoft Community
https://answers.microsoft.com > windows > forum > all
About featured
What is the Passcode or Password When Pairing ...
Sony
https://www.sony.com > electronics > support > articles
May 25, 2022 - Use the code 0000 when pairing with another Bluetooth® device. The passcode may appear as Pass key, PIN code, PIN number, or Password depending ...
How to pair Bluetooth devices: a generic guide
Mobile Fun
https://www.mobilefun.co.uk > Home > 2015 > April
Apr 20, 2015 - Speakers, headsets, car kits, gamepads: Hold down their multi-function button until the peripheral beeps or flashes. If the first response you ...
