Janome 131 newhome machine bobbin cant be filled. area where bobbin is filled is lfeless
SOURCE: Janome Memory Craft 4900 QC
its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
