I disabled the fan so i could hear the compressor. It hums but doesnt kick on.
SOURCE: I ha ve a trane xe 1200 hvac the fan runs but when
Hello Let it cool off,Install a hard start kit on the run capasitor.It is just 2 plug on wires.It just might start it,If not look for LRA amp rating on the name plate if it is 90 it is locked up.Try the kit I have seen it work.
SOURCE: my trane xr12 wont run.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
SOURCE: 3 ton heatpump package unit kicks 100 amp breaker
compressor is locked up! check the start relay and the fan motor to see if the shaft wobbles up and down if it don;t! then replace the compressor
Testimonial: "thanks it was bad compressor "
SOURCE: I have a trane XR12
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Testimonial: "Thanks for your help and a quick response. The problem was the capacitor. $30.00 to fix the problem! You saved me a lot of time and money!"
SOURCE: I have a Trane xr12 air conditioner. I turned off
Is the blower coming on inside? If it isn't, try tripping both breakers again. If the blower is working, your thermostat may be timed out or the air cond may have a timer in it that will keep it from coming on for a few minutes.
If none of the above work, make sure you didn't pull any wires off when you pulled the filters out.
