There is power to the unit and I can hear it attempting to "kick on" but it just hums for a second or two....then clicks back "off". The fan doesn't turn on in any mode and it's certainly not cooling. This just started in the last 24 hours but up until then it'd been working with no problem.
As Andy stated, sounds like a bad capacitor on the fan side. Your compressor starts to run but is shutting off on thermal overload because no fan. The hum is likely the compressor running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Bad capicator. Just replaced and should be good
Start capacitor for compresssor defective or compressor it self.
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: temperature display and "Cool" light flicker and click
It has an electrical problem, first. You (and I) won't know about needing freon until the compressor is running.
SOURCE: Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
SOURCE: Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
SOURCE: I have an old Kenmore 25,000 BTU Air Conditioner
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
