By the air pump assembly you have few hoses that are filling up all the air bags and also the air tank. Looking from the front of your vehicle the assembly for the air pump is a black box on your distant right in the back. The first hose on the box closest to you is filling the air tank (it is marked on the side of the box "6"), the second hose on the box is for the exhaust air (you should not worry about), the rest four of the hoses are for your wheel's bags. If you connect the splitters to them than you can fit the tire valves to them and fill it up with the air. The pressure should not exceed 70lb psi. Until you find the problem with the suspension, you can make the ride more comfy.If your Rover has blown hose, I would go to garage to find the spot, on mine it was well hidden under the body and between the rear differential. Hard to see and hard to diagnose. Good luck.
