Im having issues trying to assign my hot key in the game. I usually play with WASD for camera scrolling, but the WDA is non functioning for camera scrolling! Only the S works, regardless where I assign it. PLEASE HELP!!! THANK YOU!!!
SOURCE: Problem uninstalling AoE III the asians
You would probably hve had to first deinstall Asians and then AoE 3... What you can do now is manually deinstall it. It works like this: 1: Go to the folder where the game is installed (program files by default) and delete that folder. 2: open run in the start menu, type 'regedit' and hit enter. 3: A window opens. Every HKEY folder in it has a SOFTWARE folder. In one of these software folders there should be a folder that is named like the company that made the game, so for AoE 3 I believe that is microsoft. 4: Delete the Age of Empires folder in it if there are multiple Microsoft program installed. If AoE is the only prgram, delete the Microsoft folder. 5: Your deinstallation is finished! I hope this helps, Yannick.
SOURCE: Unable to install asian dynasties(game).
1. Download Microsoft Install Cleanup Utility (Search Google). 2. Run It As Administrator To Install. 3. Run It From Start > Programs 4. Find "Microsoft Flight Simulator" & Remove It. Exit The Utility. 5. Remove The Installed Folder Of The Game In Program Files Completely. 6. Restart Computer. 7. Install Game Once Again.
