This device is not working properly because Windows cannot load the drivers required for this device. (Code 31) I've updated the driver but still it registers an error.
Receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device: i. Click Start, type devmgmt.msc and press enter. ii. Locate Microsoft ISATAP Adapter device iii. Right click on the device and select uninstall iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow i. Click Start and choose Control Panel ii. In Control Panel double click on the "Programs and Features" icon. iii. Here you can find all the programs and items which are installed in Windows Vista. iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
to my laptop. I am using windows 7. I went to my device Manager, click portable devices folder, under Walkman NWZ-B163F, click properties, update software, it reads : this device is not working properly because Windows cannot load the drivers required for this device. (Code 31).When I click Driver, update Driver, it says (The Best river software for your driver is already installed. Windows has dertermine the driver software for your device is up todate.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
you need to reinstall the computer driver... the driver you install is not compatible with your device. also try to go to the device manager then update the driver of the device...
you need to connect directly with an ethernet cable. then go to the compaq/hp website and go to product support and drivers subcategory and look up isatap adapter driver
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
You install or uninstall CD or DVD recording programs.
You uninstall Microsoft Digital Image.
You may see one of the following error messages:
One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
Error message 1
The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2
A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3
Your registry might be corrupted. (Code 19)
An "error code 39" error message.
A message that resembles the following appears in the notification area:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
you can find this information and more at this site..
In the Control Panel, update the drivers. If still unsuccessful, delete those adapters, restart your workstation and reinstall drivers. Helpful to have another workstation nearby in case you need to download the drivers from the Internet.
install all the updated driver and BIOS here is the link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=INSP_DSKTP_D530
after installation of drivers...update your windows by custom update and update your hardware signature
