Emerson EWC1303 13 in. TV/VCR Combo Logo
Earl Farley Posted on Jun 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I turn the tv on but i guess a timer on the vcr shut the tv off wat the problem
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Jul 03, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292610
Points
3377
Disconnect the VCR and leave the TV on and see whether the TV gets off. If it gets off, the timer in the TV is the one that has to be reset. I do not think there is any way a TV can be switched off by a VCR, unless the power supply is controlled by VCR.
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
T.v wont turn on
The light means nothing---if TV will not turn on or comes on briefly and shuts down--could be a jammed or not working mechanism in the VCR or the TV may have a power supply problem.
Turns off 10 second after i turn it on
Check in the Menu for a sleep timer or some type of timer that is shutting it off automatically. It should be in the TV's menu under the power settings or something similar.
If that's not it, or that doesn't work for you, leave the Television unplugged for a while (long enough for all of the settings to reset) and then plug it back in and see if the problem persists. If so, you may have to get the TV serviced.
I hope this helps :)
Best Regards,
James
SET UP MENU COMES WHEN TV IS TURNED ON BUT WILL SHUT OFF IN 5-10 SECONDS
First, Check whether any auto timer option is activated...
If you are sure that this is not the problem, please revert back..
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Tv shuts down in ten seconds
You gotta change the belt of the motor charge in the vcr thats all the problem.
1helpful
How to set the vcr to record
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Remote problem
your emote control needs to be replaceit is not sending signal to the componet
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
