Televison & Video Logo
Debi Jones Posted on Jun 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 50" Akai TV - that will not turn on
I have a 50" Akai TV that will not come on right away when you push the power button. It will go through several sequences of trying to power on. It usually takes about 20 minutes. We used to be able to hold down the power button and then it will come on. That doesn't work any more. Now it has started to come back on when you turn it off. Does it need a new bulb? We do not have a manual for this TV as we bought it from someone. It works fine once it is on.
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jun 19, 2012
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329909
Points
3603
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Nov 09, 2007
SOURCE: Mitsubishi WS65513 with blinking green light
Download [email protected] .........T.
Anonymous
  • 27 Answers
  • Posted on Dec 06, 2007
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at [email protected] if this helps
Anonymous
  • 170 Answers
  • Posted on Apr 10, 2008
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Anonymous
  • 10 Answers
  • Posted on Apr 29, 2009
SOURCE: AKAI PT46DL10 Bulb replacement
order from http://www.replacementlightbulbs.com/ i did and works good now mine was type j
Anonymous
  • 4090 Answers
  • Posted on Aug 17, 2009
SOURCE: tv pops then cuts off
The right direction is right to the service center! you have a failing transistor that could catch fire.
please rate our help so we stay on the net
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
5helpful
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
2helpful
No power
If you have an external power supply check it with a voltmeter
Is the red stand by light on?
yes, but no pictures ,no sounds you will need to be a good techies to fix it.
No , open the back and check the fuse close to the connector from the power supply cable.
cheeers
1helpful
2answers
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
5answers
Akai won't turn on
my tv burned up after 1 month it kinda did what yours is doing and we had to pay fo shipping and it was almost 100.00 dollars, it has been 6 months and we have not got are tv back and they dont know when we will get it so dont send it to these idots they dont car. im in the army and told them this i will be going to irac and cant get my tv. they said send it some where else. so if i where you take it back were you got it
TV Locked
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
