Pump and filter were running fine yesterday, got up this morning and there is no water flow through the pump. We cleaned out the skimmer basket and the hair/lint basket, and reprimed the pump but still nothing. Help!
SOURCE: pool pump won't prime
check for air leaks, cover o-ring is common culprit. anything in front of pump can cause this.
SOURCE: low water flow
1. If your filter hasn't been backwashed, that's a good place to start. 2. If you haven't done a seasonal disassembly and washout of your filter, that will allow a residual to build up and keep your flow low. 3. The control selector valve...you may want to open that up and make sure there's no blockage in there as well... only as a last resort. 4. Also, remove the basket in the pump and reach in to the intake port and check for debris...that'll do it too. Let me know if you get the pressure back up! K
SOURCE: I am responsible for the maintenance of a pool
Before doing anything else, I would replace the impeller.
SOURCE: only one pool return is working, there is no
With the pump off and the basket out reach inside the pump with some needlenose pliers and see if something is clogging the impeller. It will be inside the hole behind the pump basket and will feel spongey when you reach in there. If so work it counter clockwise and when it loostens up pull it out with the pliers. Hope this helps.
SOURCE: my water flow stops with my proline pump after a
i was having the same problem. the connections were touching. once i open the moter, taped the connection from not touching each others, it works great
