Ive tried running many "fix it" programs. one program worked and the cd rom worked for 3 days,then it quit. now programs say it cant find the cd rom, though it show up on MY COMPUTER. ive uninstalled/reinstalled many times. nothing is helping uninstalled itunes. nothing. removed upper filters, nata backed up to earlier time. nope. cd rom ejects. green lite comes on for a second but doesnt run disk.
How old is the computer cd rom might be time for new one Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete or
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
SOURCE: the CD-ROM, Run but too slow.
CD ROM Drives
This site could help ya in need of the drivers .
Hope this fixes the problems you are having .
This could help ya in the way of doing this your self at this site.
Have a great evening.
SOURCE: dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
SOURCE: I need cd rom help bad
tyhere should be a pin hole in cd drive u insert a pin into to allow you to open the drive but what i suggest open the tower disconnect power to drive turn on comp then turn off then reinsert power to it then turn comp on to have it re reconize it or you can go control panel>settings>device manager(hardware manager) in there uninstall the cd drive then restart comp if this no fix find your cd rom drive updated drivers from their website if still no work buy a new one they not expensive
SOURCE: I have a particular program
administrive tools,computer management,device manager scroll down cd-dvd rom
drives you might see a yellow question mark ? right click you will have
options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer Click on
Filters Lower
Filters Upper
Close all open
programs
Hope this helps
