20 Most Recent Disney Interactive Adventures in Typing with Timon & Pumbaa for Windows, Mac Questions & Answers
0answers
I am trying to run
Be the first to answer 10/1/2010 3:26:27 AM • Disney... • Posted on Oct 01, 2010Be the first to answer
Screen display problems when running Adventures in Typing
I bought this for my daughters back in 2000. Now I find my mother wants to become a silver surfer and she would like to learn how to type letters. I tried using Adventures in typing on her laptop and saw that there were compatability issues. After a lot fo experimneting I found asloution that works every time and is as simple as can be. this is what I did (and printed out for my Mum:-)
Hi Mum :-)
Video problems with Adventures in typing with Timone and Poomba
There are compatibility issues with Windows Vista and this program
To overcome these problems we need to force windows Vista to use an
older Video format (from the days when the program was first published).
A short cut has been created and placed on your desktop.
The compatibility (properties) on the short cut have been set to –
  • Windows 95
  • 256 colours
  • 640 x 480
To create the short cut –
Place the CD-rom in the Disc bay and hold down the Shift key while the the CD-rom boots up. This prevents Autorun.
Now use Windows Explorer to look at the files and folders on the CD-rom.
Look for the Setup.exe file.
Right click on it to create a short cut that will be placed on your desktop.
Go to the short cut and right click on it to select the properties.
Now change the compatibility to the settings mentioned above.
Remove the CD-rom from the disc bay.
This is how to use the program Adventures in typing with Timone and Poomba on a computer running Windows Vista
  1. Do not put the CD-rom in the computer until you are asked
  2. Indentify the shortcut/icon on your desktop to start the program
    Click on this shortcut/icon
  3. When the computer asks for the CD-rom, place it in the disc bay and wait for the program to start.
  4. Use the program as normal.
  5. To quit the program so that it saves the progress you have made – use the QUIT symbol in the program’s screen
  6. When the program has shut-down, remove the CD-rom from the disc bay
Note that steps 1 through to 7 have to be done every time the program is started and stopped.
You will not have to do anything to put settings back to where they should be – Windows Vista will do that automatically.
This is how to stop any program if you are having problems and can not see how to stop it.
  1. Press the following two keys together Ctrl Alt
  2. While holding those two keys down, press a third key – the Delete key
  3. A menu will pop up.
    Click once on the Task Manager option
  4. A new window will open with a list of the programs that are running on your computer. Click once on the program that is causing the problem.
  5. At the bottom of the new window click on End Task
  6. The program that was causing the problem will be shut down for you.
Note that using this method is a sort of emergency stop so it will not save any new work you have done on the program/file.
6/13/2010 1:40:12 PM • Disney... • Answered on Jun 13, 2010
2answers
When i try to install
hi .......
right click on the playing icon and click on properties click on compatibility and run it using the compatibility of win 95
6/13/2010 1:32:13 PM • Disney... • Answered on Jun 13, 2010
I can not import a
This error message simply means that the file format the image is in currently is incompatible with your current version of the game. try converting the image to a different file type using http://www.coolutils.com/online/image-converter/ Most image programs use 2 file types. JPEG and BMP. Hope this helps
10/9/2015 2:14:15 PM • Disney... • Answered on Oct 09, 2015
2answers
I can't upload my coins
I can't upload coins either... I think it's a problem with club penguins servers because other people have been having the same problem. We will just have to wait and see if cp fixes it.
12/20/2014 7:46:19 PM • Disney... • Answered on Dec 20, 2014
Toontown fille explorer
the solution to that is to subscribe so you can leave Toon Central
5/23/2014 11:24:45 PM • Disney... • Answered on May 23, 2014
3answers
I bought a Disney Animated
You might be able to find a torrent for it. www.thepiratebay.org
2/11/2014 1:46:16 AM • Disney... • Answered on Feb 11, 2014
I have uninstalled DICG from my laptop but my disk
Try program like CCleaner - it will clean the mess after no longer installed programs and probably free your disk space.
9/1/2013 8:17:31 AM • Disney... • Answered on Sep 01, 2013
Unlock code of split second?
kode'nya mna?
3/31/2013 7:54:43 AM • Disney... • Answered on Mar 31, 2013
No sound at all!
There can be a host of problems with why you have lost sound ( could even be your tv via external audio ).I'd definately contact Sony and explain ; they're very good. They even replaced my son's PS2 which he'd already had for two years as the picture was wobbly : new one delivered next day and old one picked up ( all you need is the original box and proof of purchase, if it's second hand or you've thrown the box away, well be careful with 2nd hand electrical goods and always keep the box and receipt ! ).
7/24/2009 10:53:03 AM • Disney... • Answered on Jul 24, 2009
Instructions
press b and fight with a
1/17/2009 10:50:09 PM • Disney... • Answered on Jan 17, 2009
Play station 3 only shows white bars floating on black screen
Personally I do not know the answer to this question but, looking on the internet I've found people with a similar problem who fixed their problem by replacing their cables.
"sounds like a ground loop. Make sure your not using one of those cheap$50 connectors that you plug all your consoles into and then plug (it)into the tv, also watch the wires crossing each other, electricalagainst HDMI, composite and so on. Keep everything real neat andseparated back there."
1/4/2009 8:50:37 PM • Disney... • Answered on Jan 04, 2009
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
4/14/2024 5:15:47 AM • Video Game... • Answered 2 days ago
Solitaire Customer Service Call 1-8O5-225-6690 We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
4/13/2024 3:59:39 PM • Video Game... • Answered 2 days ago
I need the instructions for Electronic Victory at Sea by New Entertainment.
Victory-At-Sea-manual.pdf
Mac Game Store http://cdn1.macgamestore.com > manuals > Victor... PDF To get to the end game you must build your fleet, attack enemy shipping and support landing craft as they attack ports. You can also enter friendly ports and ... 7 pages
Digital Victory At Sea Rules PDF
Warlord Games Store https://store.warlordgames.com > products > digital-vict... This rulebook is the ultimate resource for Victory at Sea players. It contains: The complete rules for fighting naval battles, including the use of aircraft, ... https://www.google.com/search?q=electronic+victory+at+sea+instruction+manual ..
4/10/2024 7:59:57 PM • Video Game... • Answered on Apr 10, 2024
Disney Interactive Adventures in Typing with Timon & Pumbaa for Windows, Mac Logo
7 questions posted
Top Disney Interactive Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Disney Interactive Video Game Consoles & Games
Most Popular Question
screen display problems when running
  • Video Game Consoles & Games
