Does anybody know the code to reset my sky tv remote for 42pw23p tv? the volume does not work
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
SOURCE: Do not have manual but I need the TV code to
The TV code for a remote is set by the remote manufacturer and not by the TV manufacturer. You'll need to check the remote manufacturer's website for a list of codes. Or get a new remote control which will have the list of codes with it.
SOURCE: codes to make my Time warner remote control the tv
http://www.timewarnercable.com/MediaLibrary/1/1/FAQ/documents/UR5U-8400A_UniversalRemote.pdf
At least all the TV codes are there....good luck
SOURCE: TOSHIBA 42PW23P rear projection television
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
Example Photo:
You can see more examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
