I am trying to set the APN for Straight talk but the values are different in my phone. I tried the alternate values Straight Talk provided but cannot access the web still.
SOURCE: volume problem razr v3 to low
check out the equalizer settings if it is ok then try to reset your fon if it doesnt work then check out the speaker of your fon it might be damage.thats are the all way to solve your problem.
SOURCE: razr v3 setting up voice mail
Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
SOURCE: phone makes a low buzzing noise whenever try to talk on it
to change the buzzer,the microphones,clean-it and hot it
you can ask -me by address:
adamaf [email protected] /+225 0645 4954 IN COTE DIVOIRE.
SOURCE: blocking calls
no what you have to do is go to call set up on the menu and then select all calls hide id or next call only hide id .
SOURCE: Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
