SOURCE: Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
I disconnected my incoming phone line and connected my VOIP line 1 to my R11 wall phone jack. This feeds the signal to all phone jacks in the house.
I also use the VoIP to fax and send data using my PC modem.
For Fax
Use *99 as a prefix for any number you are faxing or dialing to.
Dial-up
1. Configured area code dialing rule in Phone
SOURCE: I changed my internet service
You can check the settings of router with below method.
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
Then click on WAN settings set it as your internet service provider settings enable DHCP
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
