Computer won't turn on. No status lights
This is an obvious board issue if your not getting any lights at all battery blink or HD lights no screen BIOS board is dead, you may want to check to see if power is going from the plug in plastic pin on the board as well the plastic input pin may be solder split or cracked and not connecting.
So the obviously fix for this is take it in to a tech and have them test the board out to see if your getting power to the power button. If your not getting anything showing with even the battery charge indicator and all black out. Board replacement is inevitable, I dislike being the delivery person for the bad news. This does happen...............John
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
SOURCE: I have a Toshiba Satellite Laptop Model A15-S129
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
SOURCE: DC in light flashes orange
You need to test the AC Adapter For Correct Power Flow-Through... Use A Multimeter (available at any Home Improvement Store)
If That Tests Good.....
You Will Need To Test The DC Jack (the port where your Charger Cord Plugs Into On The Laptop.....)
If An Incorrect Adapter Was Used, You Might Have Shorted Out The Motherboard..
SOURCE: My laptop Toshiba Satellite A105 - S4334. Problem:
This is a common problem with the Toshiba laptops. My freinds laptop did the same, the part you need to replace it with is hard to come by. Good luck!
SOURCE: D/C power jack
http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
Testimonial: "budmrtn, thank you very much. It was very helpful. I was able to disassemble and assemble my laptop in no time."
