Computers & Internet Logo
Anonymous Posted on May 13, 2012
Deleting old SP1 partition on dell 2400
I reinstalled a new installation dell SP2 XP Home Edition on hard-drive,now when i reboot 2 XP Home Edition show on screen,1st one is the new SP2 I installed, 2nd one is SP1 original factory installed corrupted disk/root and want to remove it from hard-drive or copy data off to a usb flash drive/dvd-cd.tryed of sudden death stop screen popping-up after a restart ?
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on May 14, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060827
Points
15385
Sound like you have two versions of the operating system out there. Not sure what your question is. If you want to remove the old version you should have done that while you were doing the installation. That would have been easy by just telling the system to do it for you.
Now you will probably need some type of partitioning software and i'm not sure if you just delete it if it will cause problems when you try to boot because windows knows it's out there.
If I were you, I would just reinstall windows and clean the disk of everything. It shows you what it finds out there as far as operating systems, so just delete them both, then do a quick NTFS format of the drive and reinstall windows.
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Mar 15, 2008
SOURCE: Medion pc keeps rebooting just as starting to load win xp home
sorry, my computer just hanged, we can continue the chat in skype, my username is : ronenfe.
or in messenger : [email protected] (this is also my email)
or in icq: 18300905.
Anonymous
  • Posted on May 30, 2008
SOURCE: New Hard Drive Dell Dimension 3000
you need the video and audio driver disc that came with the pc also
Anonymous
  • 119 Answers
  • Posted on Jun 20, 2008
SOURCE: Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Cytherian
Gary
  • 126 Answers
  • Posted on Dec 30, 2008
SOURCE: How to install new hard drive
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Anonymous
  • 133 Answers
  • Posted on Jun 11, 2009
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
2helpful
2answers
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
1helpful
3answers
Sata hdd not Detect
To install Windows XP on SATA or advanced IDE hard drive, you will need to insert a driver diskette at the time of starting the installation process and pressing "F6". For more details visit the link below:
http://ufixitnow.blogspot.com/2009/04/oem-driver-support-during-windows-xp.html
1helpful
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
2helpful
3answers
Which Service Pack is included with my Win XP Home Edition Version 2002?
Windows XP Home 2002 is Service Pack 1 only:
Buy a newer version.
Do not forget to rate the solution.
Many thanks.
10helpful
5answers
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Loss hard disc capacity
Did you happen to re-install XP before this happened? WinXP prior to SP1 can only "see" HD's up to 127G, so that might cause your problem...make sure SP1 or SP2 is installed, or try Partition Magic and see if that helps.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
