20 Most Recent
Dell Lattitude D600 Notebook Questions & Answers
Erratic keyboard
Sounds like an driver update needed to your touchpad software. Did you by any chance spill anything into the keyboard. We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
Need a bios password on the hard drive for a dell
To reset Bios Password
- Turn your computer off.
- Unplug all the cables.
- Open the tower.
- On the System Board, you can find PSWD jumper placed in pins.
- Remove it and from pin 1 and 2, then put it in 2 and 3.
- Turn the computer on.
- turn off the computer and put the jumper back to the same pin.
- Start the computer and your BIOS password is reset.
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
MY MOUSE KEEPS LEAVING THE SCREEN, AND GONE FOR 10
Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5
Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
I have a Laptop Dell Latitude D610, As unit
you will need to install a software dvd player, try googling something like dvd player windows (whatever version u have) and free, you should probably have several to choose from.
I have a laptop that had windows 2000 professional
Hello Coreymanis,
You need to purchase the windows XP CD to get the Genuine CD Key.
You can reinstall windows 2000 Professional if you have CD Key of it, but it needed the CD also. If your friend having the CD you can use that CD and use the CD key which you have.
I suggest not to install windows 2000 professional because this has been expired as per Microsoft and no support available in future.
I put a new hard drive in my laptop and i keep
henry_holmes
If you are still having trouble with the drive being detected the problem may not be with your hard drive but the computer. If you got the same error on your old hard drive I would try it on another computer to see if it is detected. If it is then most likely there is a problem with the motherboard.
Let me know if you have any more problems or questions.
Issken
My friend has asked me to fix his computer it
The life of a battery is largely determined by the number of times it is charged. After hundreds of charge and discharge cycles, batteries lose some charge capacity, or battery health. To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition, and more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear you should consider replacing the battery.
I hope this helps and good luck!
How to erase a forgotton password from BIOS of
Open the cover of your computer and look for a lithium battery inside remove the batter for a sec or look for a pin that says 'CMOS' move the pin to 2-3 for a sec then back to 1-2, your bios will be reset(aplicable in both desktop and laptop) hope this help
Flashing Lights On My Computer?
You've changed the batteries, but are they fully charged?
I usually leave my charger in all the time when using the laptop as Advent laptops have bad battery life.
Try charging it for max 8hours. If the problem stil persists,then i guess its something internally wrong with the laptop?
Or even, the charger wire may be a bit loose which is preventing it from charging the laptop either completly or partly.
Hope that helped
http://stores.shop.ebay.co.uk/Sabka-Hosiery
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
