SOURCE: jvc lcd cracked screen
LCD is one of the expensive part of a Monitor. maybe you can buy a new one because if you choose to repair it, it cost the same when you buy a new one.
SOURCE: Broken LCD
I have a 52" Samsung Series 5/ 530 Model LCD Flat Panel and I cracked the screen. The screen on the outside is not broke nor scratched but something hit it and now when I turn the tv on- it looks like i hit it with a hammer. How is this fixed? Can I do it myself?
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
SOURCE: CRACKED LCD PANEL Vizio GV42L 42 in. LCD
We have 42 inch Vizio LCD's in refurbished condition at the repair shop. The glass LCD's are around $230.00 for 42 inches. This is only for the glass panel and doesn't include the CCFL assembly which you probably don't need as its just the glass that's cracked.
Have a professional service technician install it as the LCD is very thin and extremely fragile and can easily crack under it own weight if handled wrong. Plus there are ribbon cables that require skill to attach and detach successfully on the control driver board.
We have all parts for Vizio, Samsung, Sharp, Toshiba, Panasonic, Philips, Akai, Sony, Maxent, Proscan, LCD and Plasma tv's.
E-mail me for more info...
SOURCE: large LCD cracked screen from impact, worth repair?
Cost alot to replace LCD screen not worth the money.If u can find it on Ebay bad PCB,and a
good LCD screen is might worth to repair.
Testimonial: "thanx for fast and easy to understand answer!"
