erik ragma Posted on May 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Crackling noise with my volume knob when i turn the volume
I have a problem with the volume control of my integrated amplifier, everytime i turn the volume theres a crackling noise coming out from the speakers, specialy on the left channel
Anonymous
Level 3:
  • Master 807 Answers
  • Posted on May 06, 2012
Anonymous
Master
Level 3:
Answers
807
Questions
Helped
232279
Points
2344
It's probably dust in the volume control. It gets in between the carbon track and the wiper that rotates on the track, or the resistive / carbon track inside the control is wearing out. As yours is stereo there will be 2 tracks and 2 wipers, one could be worn more than the other.
This should give you an idea. Inside Pot
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Mar 22, 2008
SOURCE: JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Anonymous
  • 5 Answers
  • Posted on Aug 28, 2007
SOURCE: Integrated Amplifier - Volume Control Problem
Hi there, get down to your local electronics supplier and buy a tin of spray switch cleaner. Try and spray some into th v/control and do the other controls at ther same time, this should solve the problem
Anonymous
  • 2071 Answers
  • Posted on Jun 08, 2009
SOURCE: technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Anonymous
  • 24 Answers
  • Posted on Jul 26, 2009
SOURCE: NAD 3020a crackle in right channel regardless of volume.
more than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
perkoo
Denis
  • 17 Answers
  • Posted on Dec 21, 2009
SOURCE: Technics Integrated amplifier su-v85a speaker
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: [email protected]
2helpful
2answers
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
2220 B
Do you mean just crackling generally or it crackles when you turn it up or down? I have a Marantz PM350, old but still great performance, and I periodically take the volume knob off and spray down the hole with a cleaner/lubricant spray. This does the trick!
I cannot get equal volume on both channels. It snaps crackles,
If it's an old type control then you can spray it with Servisol switch cleaner. You might have to take the top cover off to get better access.
1helpful
I HAVE A NOISEY VOLUME CONTROL ON MY AMPLIFIER IT CRACKLES HOW CAN I STOP IT
No fear.
Try to reachinternal side of front panel with volume controls. Put some paper towels under the front panel. Pour lighter fuel into every dirty volume control turning knob around several times.- It will rinse out all dirt from carbon track or contacts. (I don't know what kind was used).- This is only temporary solution, good for one year or so. Proper solution-> unsolder volume control, open it up , inspect and clean or replace for a new one. It will work, I did it hundreds of times...always with positive results.
SU-V60 volume knob needs fixing. Very loud crackling noise, volume goes up or down on own.
I reckon this could be an older type of volume control, which if it is a spray of Servisol Video 40 on the workings of the control (inside the unit if you can) should correct it. Otherwise it's an IC that controls it and needs to be replaced.
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
4helpful
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
1helpful
2answers
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
1helpful
Technics su-v560 stereo amp crackling
 Grubhead
Grubhead
SmartAviator
SmartAviator
