Only shuts off when using auto brew cycle, Sometimes I wake up 2 partial pot and it is not hot. coffeemaker turns off. That makes me very unhappy! If I change the start time slightly it will work fine for couple of days. Love my coffeemake only 5 months old. I did not sent in warranty, What can I do?
SOURCE: Is their anyway to turn the beeps off when the pot of coffee is done?
Disconnect the beeper.
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
SOURCE: We have a CBC-1600 10 cup coffeemaker. after
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
SOURCE: Cuisinart coffeemaker DCC-450 switch keeps turning off by itself.
There is a defect with your coffee maker. It uses a momentary switch,
but is supposed to stay on for 30 minutes. I believe there is a common
failure due to heat sensitivity of an IC on the board. I suspect this
is a timer chip. See my other postings on this.
-Joe
