Question about Cuisinart DCC-1200 Coffee Maker
I have performed the self cleaning function several times in a row - using the vinegar/water solution. The slef clean light does go off - however, each time I brew a pot of coffee, it comes on again at the end of the brew cycle. Any help?
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Posted on May 01, 2013
You will be fine if f you do exactly what the Instruction Manual says regarding the self cleaning: If the Self Clean light begins to flash when the coffeemaker is turned on, it is telling you that the calcium buildup is interfering with the functioning of your coffeemaker and the flavor of your coffee. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Press the Self Clean button. When the self clean light glows, turn the coffeemaker on by pressing the flip switch to ON. The Self Clean light will shine steadily. The coffeemaker is now in Self Clean mode. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, the coffeemaker will shut off. Turn the coffeemaker ON to see if the Self Clean light continues to flash. If it does, turn it to OFF and then repeat the cleaning procedure with a fresh solution of vinegar and water. If the Self Clean light no longer flashes, turn the coffeemaker to OFF and then run one cycle of fresh cold water through the unit before using the unit again to brew coffee. otes on the Self Clean Function Pressing the Self Clean button cancels all other settings. If it is pressed accidentally, press it again to return the coffeemaker to all its previous settings. Pressing ON/OFF will also exit the Self Clean Mode and turn the coffeemaker OFF.
Posted on Nov 13, 2011
Mar 21, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Feb 16, 2011 | Cuisinart DCC-1200 Coffee Maker
Jan 24, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 15, 2010 | Electrolux 30" Self-Cleaning Freestanding...
Feb 14, 2010 | Cuisinart Coffee Makers & Espresso...
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Feb 26, 2009 | Cuisinart Grind and Brew, 10 cup, black
Feb 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Jan 26, 2016 | Cuisinart DCC-1200 Coffee Maker
5,062 people viewed this question
The brewing takes about 20 minutes and it gurgles like it is at the end of the brewing the whole time. The self clean light has come on several times and it has been cleaned several times with vinegar and DESCAL, a compound for descaling
