Is there a way to increase the modem dial tone and connect volumes on the Dell 4700 compute running WinXP SP3? I can barely hear it, but the FAX modem works fine. Henry
Go into the device manager and select the modem to change the volume.
Click Start/Control Panel/System/Hardware/Device Manager then scroll down to Modems and click the + sign next to Modems to expand and see your modem. Right Click on your modem and select Properties. When the Properties window opens up click the Modem tab and then select to change the Speaker Volume. Just slide the volume meter to the right by using your mouse pointer to increase the volume.
SOURCE: no dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
SOURCE: dell dimension computer has missing volume icon,
click on start,goto controlpanel,you will see a speaker diagram click on it to increase the volum.but if it is blunt you have to contact your IT person to install the driver you need
SOURCE: was able to get connected to the internet twice to
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
SOURCE: vno sound volume not working
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4700&os=WW1&osl=en&catid=&impid=
If you need more assistance please write back.
Please leave a rating, thank you kindly
SOURCE: Can't connect to internet, modem not found
right click on m computer- properties- hardware-device manager- check and see if you have anything with a yellow ! or ? or if you have anything listed under Modems. sounds liek you need the drivers installed-
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
click the + by communications and download the 3 listed and install on your home pc
