This may be because of your damaged SIM. Try the following: 1. Check whether your SIM is rejected by just putting the same SIM in another phone. Also, check if your SIM is a valid GSM compatible SIM. 2. Check if that your phones SIM slot is fully operational. 3. Check if you have correctly inserted the SIM.
Hope this may help you. Happy New Year to you too.
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone.Save the settings and switch off your cellphone and again switch on. then the cellphone connect to the internet...........
Just tell your girlfriend that the phone is locked. Advise her to bring the cellphone where there is a cellphone repair shop because in the Philippines. There is a lot of cellphone shop who can make the cellphone locked to open line. Meaning to say whatever simcard she wanted to, it will open all of it when she plug the simcard.
You can try a different sim to check if the problem is within the phone. If any case the cellphone recognize the new simcard it only means that the 1st simcard that youve use is faulty.If the cellphone still wont recognize the new sim card then it only means that the problem is within the phone. You can check if the phone still have a warranty for repair free of cost or bring it to a cellphone technician to fix it
Remember insert a SIM Card that is supported by your mobile phone it may be locked to a certain provider
hi, check your sim card first ,clean it...next step is clean your simcard interface by eraser or lacquer thinner ...if still not works ,the sim card driver of your phone is need to replace..this simcard driver is small chips that makes the simcard working ,if it is damage the simcard interface did not recognized the simcard...if the first and second solution not works ,go to a cellphone repair shop to change your sim card driver... i hope it will help you..thanks
HI friend, First of all I am not too old to be called as Sir alright? Ok here is what you do, remove the simcard from the cellphone, gently rub it clean with a clean soft cloth(a lil dilute spirit wud be helpful) and then insert the simcard back into the sim card slot.It works 99.999% Have a great day:):) Plz rate me for my solution so that I can improve myself and be more helpful:):) Prasanth83:):)
