System Password? No Such Thing!!!
The Three Types of Passwords are:
Bios Password - which is a password the comes up before the machine will even start booting. If you set this password, you should know it. The only way to remove a Bios Password if the take the laptop apart and remove the CMOS battery that is on the motherboard and let it sit for an hour or so until the computer completely loses memory of everything including the date, time, passwords.
Hard Drive Password - The hard drive password is set by the owner of the laptop to prevent thieves from getting to sensitive data if the laptop is stolen. 99% of the time if someone don't know the Hard Drive Password, then the laptop is stolen. If you're smart enough to set the hard drive password, then you should be smart enough to remember it. The real owner can sometimes set the password remotely once the laptop is stolen. The only way to remove the hard drive password is type in the correct password.
Windows Password - This password is associated with a user id that shows up once windows has completely booted up. If you forgot this password, it can be reset depending on the operating system.
Windows 7 requires a Password Reset Disc that everyone should take the time to create if they want to use a password on their user account. Without the disc that was created on that computer you won't be able to get in.
Windows XP and Vista - Turn off the computer, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select Safe Mode and let the computer boot. When it comes to the login screen it will show the Administrator account and the user account for which you forgot the password. Click on the Administrator account and just click ok or enter for the password (hopefully you didn't create an Administrator's password and forgot it too). When you see the windows desktop in safe mode it will look differently. The icons will be bigger and the screen darker, but that is normal in safe mode. Click Start/Control Panel/User Accounts and select the user account for which you forgot the password, then select REMOVE PASSWORD, click OK and reboot your machine. This time let the computer boot up as it normally would.
What version of windows are you currently running? More details are required here so I can assist you better...
