Hitachi Touro Desk 2 TB USB 20 External 0S03289 Black [Amazon FrustrationFree Packagi Hard Drive Logo
Posted on Mar 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its making a strange noise and my computer isnt recognizing it
Brian Sullivan
Level 3:
  • Hitachi Master 27,725 Answers
  • Posted on Mar 24, 2012
Brian Sullivan
Hitachi Master
Level 3:
Answers
27725
Questions
Helped
5670304
Points
79191
Make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Ktm 50 jr Making knocking noise when starting and tutning off, allready replaced kick start, bushings, and bottom end.
just starting and turning off, strange would be good to hear the noise if possible. just double check exhaust isnt loose to cyclinder and no leaks there
Feb 15, 2013 • Motorcycles
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
2answers
The harddrive was connected with my pc, but it was all turned off. a short circuit must have happened that day, i found the harddrive turned on. probably the arriving electricity turned it on, (it often...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
My hard drive is making funny noises and isnt recognized
If you get it going, you should immediately store all the data on another drive
Stopped working
Any sort of noise form the disk is not a good sign. i suggest you look for the warranty card & take it to the shop you bought it from. you could be having a defective ****
4answers
My maxtor 200GB drive is not recognized by my CPU anymore!
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Computer not loading up strange symbol indicating some problem
That is the hard drive symbol. The noise is most likely the hard drive, and I would say that your hard drive has failed/crashed and needs to be replaced.
2answers
Phillips external hard drive
There is a chance that the hard drive itself is at fault and the computer cannot recognize it try using it as a slave drive in computer. and use a recovery cd from boot to check it out
You could use thee ultimate boot cd (download) to check it
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
