Half clear picture the other half is scrambled
SOURCE: toshiba 61 inch rear projection scrambled picture
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Testimonial: "Very useful and considerate. thankyou"
SOURCE: HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a
closet somewhere and check all connections. Check your hd receiver and
you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
SOURCE: turn on tv and get
I would suspect your power supply deflection board is failing. Normally these tvs have a problem with the hyper board in which the image is scrambled and then clears up. Your problem is just the opposite and indicates a part is heating up on the power board. A good visual look at the board will be your best starting point. Look for burn marks, a capacitor that is rounded on top or leaking. Also look carefully to ensure your CRT bulbs have not leaked fluid onto one of the boards.
It's a starting point.
