PLEASE DIOGRAM OF F61 PROBLEMS
SOURCE: Panasonic Sa Ht 70 Problem F61
Hi, F61 usually means that the unit has some sort of DC error internally. One of the amplifiers could have failed. The HT70 is an older unit and dry joints around the voltage regulator and power amplifier is also very common. Also check that the fan is in good order.The unit will most likely have to be checked by a professional tech.
SOURCE: Panasonic SA-HT740
The F61 fault means the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new. Although I have the SA-HT995 system, it sounds like the same fault.
Still under warranty? Get it fixed for free....
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
