20 Most Recent Panasonic sa-ht930 Home Theater Audio System SA-HT930 System Questions & Answers
Panasonic SA-HE200 AV Control Receiver. Where is the R1702 and the Q1702 located on the circuit board of the Panasonic SA-HE200 please?
Question edited for clarity and toss in some CAPS. Question moved from Misc. Tanya has the Service Manual
panasonic sa-he200 sch - service manual
Elektrotanya https://elektrotanya.com > download ยทTranslate this page Download PANASONIC SA-HE200 SCH service manual & repair info for electronics experts.
PANASONIC SA-HE200 MANUAL Pdf Download
ManualsLib https://www.manualslib.com > manual > Panasonic-Sa-... View and Download Panasonic SA-HE200 manual online. AV control receiver. SA-HE200 stereo receiver pdf manual download.
Panasonic SA-HE200 AV Control Receiver Manual
HiFi Engine https://www.hifiengine.com > manual_library > sa-he2... Specifications. Tuning range: FM, MW. Power output: 100 watts per channel into 6? (stereo). Surround output: 100W (front), 100W (center), 100W (rear). ..
2/1/2024 4:05:19 AM • Panasonic... • Answered on Feb 01, 2024
2answers
Remote control
Which universal remote do you have? Any of the Harmony remotes should be able to control the panasonic.
10/25/2016 3:19:05 PM • Panasonic... • Answered on Oct 25, 2016
2answers
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?this is for the Panasonic sa-ht 880.
11/30/2014 2:01:14 AM • Panasonic... • Answered on Nov 30, 2014
0answers
Code F61
Be the first to answer 10/11/2014 3:03:29 AM • Panasonic... • Posted on Oct 11, 2014Be the first to answer
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
7/28/2014 10:35:15 AM • Panasonic... • Answered on Jul 28, 2014
Cannot control receiver from remote
Does the power button on either remote work? If nothing works, we'll try to see if your remotes are actually functioning. Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen. Take your remotes and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see, on the screen. (Cool right?) So, if your remotes are working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.) If the LED's are not lighting up, (and you've verified that your live digital video device can "see" these type of LED's), then your remotes are dead. Yes, it's unlikely that both your original and universal remotes are both dead - but it's possible. If the LED's are lighting up then you have one of two problems. One: the remote is not correctly paired with your system, and two: the IR receiver in your system is pooched. Let's look at the fixes for these. Not correctly paired. Your universal remote has some sort of programming or learning function. Try programming it again, or programming it to a slightly different model of receiver and see if it works. If you've "learned" it from your original remote and it's not working, then maybe your original remote isn't paired correctly with your unit. If this is the case, contact either the place you bought it, or the manufacturer and tell them what's happened. You can't change how the original remote "talks" to your system. The IR receiver in your system is pooched. Contact the place you purchased the unit, or the manufacturer, and have SA-HT930 system serviced. If you're handy with electronics you might get lucky and find something burnt out inside, but in my experience this will be %0.25 successful. If the rest of your system works perfectly, I wouldn't crack open the case - it's not worth your time.
7/8/2014 1:40:35 PM • Panasonic... • Answered on Jul 08, 2014
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
5/5/2014 7:25:28 AM • Panasonic... • Answered on May 05, 2014
0answers
I need to buy a output ic, where can I buy one for good price?
GO TO AMAZON
12/3/2013 4:45:22 PM • Panasonic... • Answered on Dec 03, 2013
0answers
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
4/16/2013 1:48:56 PM • Panasonic... • Answered on Apr 16, 2013
0answers
99 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
sa 100bt f76 error after taking unit
  • Audio Players & Recorders
