Your TV can only present resolutions as good as the source you provide it. For instance a standard DVD likely provide 720 or less resolution while a good Blu-Ray will deliver 1080 content to you TV and show "1080" as it receives the data from the Blu-Ray player as the movie begins. You may see this number switch often even on 1 single DVD as the resolution often changes between movie trailers and the main content and menus can all have different qualities. So, your TV is only as good as the content you feed it. It can not make the content better then the original source you provide. Hope that helps
SOURCE: how do I get 1080 on TV
You only get it if they send it. Only Blue Ray DVD's are in 1080p and games I suppose, as of this time. everything else is 480i or 720p. As your manual says "TV CAN GET"--- not produce what isn't there. I hope this helps.
