SOURCE: Where can i download Asus P5GC MX/1333 Motherboard drivers?
Hey,
drivers and software for your motherboard p5gc mx 1333 are available on this asus page
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5GC-MX/1333
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: P5GC-MX/1333 internal audio speaker is not working
Open your case and find a cable that comes from your internal speaker and connect it to pins on motherboard marked pc speaker or int.speaker or speaker
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS
Yes you can put a 1 gb card. The motherboard has PCI Express so you don't have to worry to much. The older AGP cards are almost gone.
You could buy a GeForce 8500, 8600, or 8800, or the 9 series. You can also buy a Radeon HD 5870 or 5570.
If you need further assistance, please post. And do not forget to rate.
Thank you for using FixYa
