I have a Hitachi WH 18 DFL cordless impact driver, which I love. It has the quick release system for changing bits. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit doesn't budge. The bit is not bent. I am stymied. Can you help?
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Testimonial: "Problem solved!"
Actually, this cause is recorded lots of time when we do heavy drill machine. This problem happens lots of time. Perhaps, there is no solution for it and now time has been came to bring new one drill machine. If you are going than don't forget to checkout here for any of tool or drill machine. Dewalt Tools
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
SOURCE: My cordless drill smells when it is being ran. Is
could have trash in motor. clean motor with compressed air.
