Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
My charger displayed cold/hot pack delay during charging
Posted by lsl_lara on
Repair Ahjoshe
  • Dewalt Master
  • 885 Answers
This is indicating the battery is too hot to charge, usually after coming off the tool right after some hard work. During the charging process the battey heats up so if you charge a hot battery, thereby making it hotter, you shorten the lifespan of the battery considerably. If you are getting a hot/cold pack delay indication on the charger, it should automatically start charging once the battery has cooled down sufficently.
Posted on Jan 30, 2012
Joseph Taka
Unplug at wall then plug back in a few times.. worked for me. Also if wont charge then get a 12v batter charger and excite it a few times or charge it for a few minutes to put some life back into it.. if that dont work open the battery and find the dead cell and try shock it back to life if that dont work swap that cell with a better one from any old battery.. better yet if it's the old NiCd battery then rip out all the old cells and insert lithium cell pack just solder the terminals and your away laughing
Posted on Dec 07, 2019
1 Related Answer
Anonymous
SOURCE: i have a 18 volt dewalt patter pack that has one
same prob here, except its just one pack. mine is a 14.4 impact driver
Posted on Nov 21, 2010
My Porter Cable 20maxv charger is blinking red and won't charge the batteries. Just got it for christmas and has only charged the batteries twice
do you live in a cold region? batteries or the charging pack wont charge when cold and often display rapid red blinks
Jan 20, 2017 | Porter Cameras
I have a Lincoln 14.4-18v charger that showing a hot-cold pack delay. I have two batteries that haven't been used in a few days and the code comes up on both.
Insert batteries in and out of charger quickly several times to help make better contact, its worked for me in the past. seems like contacts get dirty and this gets them shinning again.
Jan 31, 2016 | Drills
Makita DC1414 7.2v - 14.4v Charger NiMH & NiCD Genuine Makita Charger. What does the Delay Charge (to hot ) mean
Here is the manual for your charger. Delay charge means the battery is still hot due to removing it from a used condition or left out in direct sun or heat. https://www.homedepot.com/catalog/pdfimages/0d/0d112214-cc51-4a32-b919-5ea3d317550b.pdf
Dec 13, 2014 | Makita Drills
Battery won't charge. Light pattern on the charger is " ._._._. Is this battery bad.
What is the residual voltage on your battery, if it is too low, charger will not engage. If the voltage is below the threshold allowed, simply jolt the Nickel Cadmium battery with a car charger to bring it up, then install on charger.
May 14, 2014 | Dewalt 18 Volt Compact Drill Kit
DeWalt 18v batteries charge light flashes quickly why?
Here are the codes for Dewalt Charger Flash indications:
---- ---- ---- ---- ---- ---- ---- Charging
------------------------------------ Charged
----- - ----- - ----- - ----- - ----- Hot/Cold Pack delay
- - - - - - - - - - - - - - - - - - - Replace pack
Feb 07, 2011 | Garden
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
I can't find the charging manual and I am intuiting from the drawings that if it has a steady flashing red it means it's charging, but I would like to read the instructions.
Operator's manual for DW926K-2 is here. It doesn't specifically address solid red light, but that's what mine does when I first put it on, so solid red indicates that it is charging.
If it is flashing the red light with two fast blinks followed by a
pause. This means the power source has out of spec for the charger (such as a generator not producing electricity at 60Hz).
If the red light flashes long, then short, you're in Hot/Cold Pack Delay mode which means it won't charge the battery until its temperature has stabilized.
I hope this helps! If so, please vote. Thanks.
Jun 13, 2010 | Dewalt Cordless drill/driver kit 9.6 volt...
HOW WILL I KNOW IF BATTERY IS BAD OR THE CHARGER
ON UR CHARGER U WILL FIND: Diagnostics with LED indicator are 5 indicators to communicate battery charge status: charged, charging, power line problem, replace pack, and battery too hot or too cold.
Jan 16, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
9,744 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
