Apple Power Mac G4 Desktop Logo
STEVE SHOEMAKER Posted on Jan 16, 2012
HAVE A MAC G4 THAT I CAN'T INSTALL LEOPARD 10.5.6. HOW DO YOU INSTALL THE OS WITHOUT IT FALLING
TRIED TO INSTALL THE OS BECAUSE MAC SUPPORT RECOMMENDED IT. GOES THROUGH PRIMARY STEPS OF CHECKING DISK AND THEN TRIES TO INSTALL BUT FAILS. HAVE REPLACED HARD DRIVE,POWER SUPPLY,VIDEO CARD AS WELL AS THE OS. AT A LOSS OF WHAT TO DO. ANY IDEAS?
Jason Barnes
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 75 Answers
  • Posted on Dec 26, 2013
Jason Barnes
Contributor
Level 1:
Cheetah:
Answers
75
Questions
0
Helped
14886
Points
84
Running Leopard on a box that old is not really the optimum thing to do. It's got 64 bit architecture and being a G4 is 32 bit, your box will not take advantage of the speed increase. As a matter of fact, and this is from experience... your machine will slow to a crawl. I wouldn't stick an OS newer than Panther on a box that old. Even Tiger slowed it down to ungodly proportions.
5 Related Answers
Anonymous
  • Posted on Feb 02, 2008
SOURCE: unable to upgrade to system leopard on my eMac
I don't know that you necessarily have to get rid of your computer. I have a G4 circa 2000 with 400 MHz processor. I run Tiger OS 10.4.1 and can run Illustrator CS on my machine.
It is not running at lightspeed mind you but it still works fine.
There may be some interim updates that you need before going to leopard... I would try talking to someone at an apple store or call tech support about it. Apple is really good about customer service.
Your eMac has to be "younger" than my tower G4 Gigabit Ethernet model so don't give up too soon. I don't think CS3 will use like 50% more resources compared to CS so your computer should be able to handle it.
Good luck,
Anonymous
  • 44 Answers
  • Posted on Sep 01, 2008
SOURCE: Leopard won't install
Found this on the net:
http://www.brad-x.com/2007/10/27/howto-leopard-install-with-giga-designs-g4-upgrade/
Those upgrade cards always have given me a problem with migrating to Leopard. If you can upgrade to a used G5 or even Intel basd mac you might be more happier with less hassle.
Anonymous
  • 55 Answers
  • Posted on Nov 28, 2008
SOURCE: Can't install Mac OS X Leopard on Power Mac G5.
email me at [email protected] i have the fix for you
MacApplePi
Martin Buck
  • 86 Answers
  • Posted on Dec 29, 2008
SOURCE: The dreaded question mark???
It sounds as if your hard drive is damaged and is not mounting. As you are running OS 9 I suggest using Norton Systemworks and run it's disc repair facility Disc Doctor. This will make repairs to the hard drive to allow it to mount. (Unless the disc is too badly damaged). If this is the case you will need to replace the hard drive and re-install all your system and applications. If you haven't backed up your info, the damaged disc can be scanned and your files saved by a computer repair shop.
damien729
Damien Gole
  • 221 Answers
  • Posted on May 30, 2009
SOURCE: Canon N122OU driver for Mac OS X Leopard
Please find here the direct link to your scanners driver and manuals:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8007
I forgot my admin password for mac book 10.5.8
Tina, Follow instruction from the links below to reset password.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
admin password change OS 10 5 8
forgot the password to Mac OS 10 5 8 Leopard How can reset it
How to reset your Mac OS password without an installer disc
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
Cant find the disc on my powerbook g4
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
5helpful
2answers
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
6helpful
2answers
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Install Leopard Problem
Were you updating to Leopard from Tiger using an upgrade install? This was a common issue caused by APE (Application Performance Enhancer) a third party plugin for Mac OS X. The solution around it is to do an archive and install which will remove APE while retaining all of your data and programs. The only things reset are system configurations (Wifi passwords etc.).
Good luck
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
