I have dish network. Is that Antenna A? B?
Hi my name is Mike Houston a Social Media Representative of DISH Network, if you are trying to find the input on your TV to view DISH programming, it will depend on the connections. If you are using RCA cables (red, white, and yellow) it should be on video 1 or video 2. By using the component cable (red, blue and green) it should be component 1 or component 2. If you have any questions please e-mail me; [email protected].
SOURCE: HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Operating a Sony satellite dish is a process that first requires correct dish placement to ensure strong signal reception. Additionally, the satellite receiver must be installed, and only then can you use it to put the dish in operating order via the use of its signal meter screen. Fortunately, you do not need to be a professional to complete these operations properly.
Look around for a suitable mounting area for your satellite dish. This mounting area should be free of any debris and also allow for a flat mounting area. It's best to utilize a hand-held level to measure and make sure that your Sony satellite dish lies flush with the mounting surface beneath it. Also, look to the skies above before settling on a mounting area, as obstructions such as trees, power lines and tall buildings can block signal reception for your Sony satellite dish. Once a spot is chosen, go ahead and crudely aim your Sony satellite dish to the southern sector of the sky above. This will save you some time later when you return for further adjustments
