SOURCE: low speed fan relay for the 2005 chrysler town and country
If you are talking about the cooling fan relay for the radiator there is no low speed and high speed relay. There is only one relay and it is behind the grill revitted to the bumper rail. It is doesnt look like you typical relay.
SOURCE: Chrysler trouble code U110C on 2005 chrysler town
encrypted software ,dealer only----yes i know you are showing a reading but it doesnt mean anything or if it does it shows a different code .so your snap on or mac tools scanner is a waste of time and money.Nearly all new motors from 2005 are using encrypted software to stop general mechanics like me from working
SOURCE: power door locks on 2005 chrysler town and
There is an ecu flash for this repair. You may get the locks to start working again with a battery disconnect.
SOURCE: 2005 Chrysler Town & Country. Passenger side window problem.
HAVEK 1005 sounds right on track.... but also try this, usually works well for non functional power windows, specially Caravans.
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all local friends I recommend this fix too, likewise do the same and are happy with the solution.
SOURCE: cannot locate pcv valve on 2005 chrysler town
On my 2005 T&C with the 3300 V-6, it is in the middle of the rear rocker arm cover, directly under the air intake in front of the windshield. There is a hose about 3/4 inch thick running from there to the intake manifold near where the air filter attaches. I think it just pulls out of the rocker arm cover, but be gentle, the cover is plastic and can break.
