F3 Mag Cur??? Our oven has broken down with this error code three times in the past two months. Is this happening with anyone else? 1 comment. share. save.
... causes are the solid state relay (NGC-3005), high limit thermostat (102075), heater wire service kit (NGC-3089), and top heater (NGC-3011). F3 Mag Current.
Faults Requiring Service Call If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000. * F1: Blower * F2: Low Temp * F3: Mag Curr * F4: Monitor * F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Just two work there: 1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock. 2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Sorry to read about your problem, I hope this helps you out.
Theerror code is for the
magnetron/microwave part of the toaster. You will need to have it
serviced by someone familiar with the unit, it could be easy and
reasonable, if just a fuse blew, but not likely. If the fuse blew, it is
20amps, so something took it out. Call turbo chef, they will get you to the closest service company Here:http://www.turbochef.com
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone. Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
