Ovens Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Anonymous
Level 3:
  • Master 2,382 Answers
  • Posted on Jan 22, 2011
Anonymous
Master
Level 3:
Answers
2382
Questions
0
Helped
859815
Points
7450
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Thanks for using Fixya, let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
My oven is showing f3 once its preheated and i set the timer it keeps beeping till i shut if off...what do i do??
That F-3 is a bad oven control or a bad sensor or both. 81aa179.jpgTo verify a bad sensor unplug the quick connect and check for continuity (bad if open)
Check for continuity between each wire and ground. If the sensor is grounded it is bad
Mar 22, 2010 • Ovens
2helpful
Service code F3 appears when turning oven on and trying to preheat.
Hello there:
The dreaded F3 code means that the oven temperature sensor is bad and that it will need to be replaced simply go to your local appliamnce dealer and give them your make and model number and they will be able to get this sensor for you
Hope this is very helpful for you
Best regards michael
I'm getting a beeping f3 when I press bake. model is 31806660
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
1helpful
Shuts off when preheating with F3 or F6 error
The F3 error on this model is an open thermostat circuit. The F6 is a control or loss of power. Make sure the unit is plugged into a good 120 Volt outlet. Test this outlet with a power drill or lamp, wiggle cord in receptacle, if no other test experience or equipment is avaliable. Check the thermostate in the oven for physical damage. There may be a loose connection in the oven. This would require a good technican to find.
InMrFixIt
1helpful
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
1helpful
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
