1996 Plymouth Grand Voyager Logo
vidal gutierrez Posted on Dec 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine light po 731 - 1996 Plymouth Grand Voyager
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on Dec 04, 2011
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2962859
Points
18833
Diagnostic Test Code (DTC) P0731 is a transmission fault code and has a generic description of "GEAR RATIO ERROR IN FIRST GEAR".
The Powertrain Control Module (PCM) monitors the input shaft speed and the output shaft speed of the transmission through the input and output speed sensors. The proper gear ratio will produce a predictable difference between the two sensors. This DTC sets when the expected difference differs greatly from the actual difference between the two speed sensor readings.
This can be caused by several things including:
> Defective input speed sensor
> Defective output speed sensor
> Defective connections or wiring between either speed sensor and the PCM
> Shorted speed sensor circuit
> Open speed sensor circuit
> Slipping clutches inside the transmission
Please note that Transmission Control Module (TCM) replacement WILL NOT correct for this code.
The speed sensor data must be monitored with the proper equipment and the speed sensor circuits must be verified for proper function to determine the actual cause of this fault.
2 Related Answers
Anonymous
  • 667 Answers
  • Posted on Dec 09, 2009
SOURCE: Check engine light came on. Had diagnosed and
The 0506 code is an information code that says the idle speed is lower than expected, the problem code is the 2112 start here, this code refers to the throttle body not operating smoothly, you can remove it and clean it, check for smooth operation and check the TPS at the same time, if you cannot get a smooth operation you will need to replace the throttle body assembly, reset the check engine light and verify your repair. Hope this helps, let me know
ZX2Fast
Brad Kirby
  • 547 Answers
  • Posted on Dec 05, 2010
SOURCE: I have a 1996 chrysler
P0420 Catalyst efficiency below range.
P0731 A/T Additional Gear Ratio Error In First Gear
Your catalytic converter could be clogged up or just bad. Or, you could have a leak before the catalyst.
The other code suggest you have an internal transmission problem that is mechanical and cannot be fixed without taking the transmission apart.
Po 731 starts up in second gear
What year? OBDI or II code? PO 731 could be a transmission/ gear problem.
Hi, I don't know why my engine light on for my car at a sudden and I have taken to a autozone they told it is showing 731 and 700 error codes but now engine light is turned off. Do it have further problem?
As Long As The Light Is Off, Should Be OK--If It Comes Back On Get More Exact Code Number(s)-----There Should Be Letter(s) As Well As Numbers. Usually A Speed Sensor Will Cause This--However could be a temp. code due to low voltage at some point in time(code 700) which will generate code 731--1st Gear Transmission Code.
How i fix code po 731 and po 732 in mercury villeger
Well code 731 is for a problem with first gear and code 732 is for second gear. You'll probably need a transmission shop to fix it.
You can get a shop manual and see if you want to tackle it yourself.
How do I turn off check engine light after fuel sensor code Po 193
After the problem is fixed and the code is erased with a scanner or code reader, the light should stay off.
My 2000 saturns engine light came on i got codes po 341 po122 po340 po 107 po706po714po 731
my engine light also came on one day and I got the same, its common in older cars for this light to stay on all the time, you can truble shoot this by spending money on each of the engine sinsors, but i have had this light on for over 5 years and nothing is wrong with my car
I have a 1996 chrysler town and country LXI. My check engine light came on about 2 weeks. I took the van into brake masters so they could perform a free check engine light evaluation. the guy at brake...
1helpful
2answers
Check engine light came on. Had diagnosed and these codes came up: PO 506 PO 2104 PO 2112 Where should i start??
Start with the throttle sensor on the gas pedal, check with voltmeter one wire should have 5.0 volts one of the other should get more voltage as you press the gas pedal.
1helpful
I have a 2001 nissan sentra xe and my check engine light is on i had a diagnostic test and the codes PO 455 and PO 0440 came back what does this mean?
PO 455- Evaporative emission control System leak detected (check exhaust system, egr valve, or entire intake and exhaust system)
PO440- Evaporative Emission System Malfunction (also check oxygen sensor)
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
