Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
To unlock the keypad, select Unlock, and press * within
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
To answer a call when the keypad is locked, press the
call key. When you end or reject the call, the keypad
automatically locks
It sounds like the sonata computer might be corrupted. Do you use mp3, or ipod to play music through your stereo and or do you play burned music? It's my belief that the computer can become corrupted from maleware code. Also do you know if there was any command start installed or removed? Command starters are notorious for causing computer glitches and malfunctions in the locking mechanisms.
the only options Ive found for this are if you hit a button with the slider closed it asks if you want to unlock the keypad. Then you hit the right top button (says "ok") and it unlocks...this stays like this until you open and then close the slider. This is the only way I know of to unlock the keypad, I have not found any other way in settings menu or anywhere else. Good luck!!
