How am i going to reset this error? I tried to boot the printer but the the printer gives the same error 116-321
SOURCE: oki b6200 web-interface-login
Log in as root (lower case) and put last 6 digits of mac address in uppercase as password.
SOURCE: oki b6200 printer error
How did it get error? In the most case that error shows the time to replace another Fuser part.
The Fuser was ruined if you print over maximum number of pages (200,000 pages for eg.). If not the component of printer's Fuser is ruined, such as sensor, this is the most case that I have usually seen.
I think it's simple. But how to find it is a little difficult.
SOURCE: Oki b6200 has an error code of 006 335
This error code is associated to the scanner unit, try cleaning it
SOURCE: Replace fuser E error
It sounds like your fuser is broken, you should be able to pick one up cheap on ebay, I have had the same issue and was toying around with it 4 days then I just gave in and got a new one, error went away!
sorry I couldnt be more helpful.
Paul
SOURCE: Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
