Its a world edition. With the SD card inserted, in the options>advance options>media card, media support in on, no encryption, mass storage is on, auto enable mass storage when connected is on, it displays; media card cannot be read, verify that the memory card is formatted. I tried a different card but got the same response. Thanks.
SOURCE: Blackberry 8830 Power Failure
you need to buy a new battery coz blackberry battery are not working longtime
SOURCE: BB 8100 not recognizing micro sd.
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
click start click to open on my computer you should see your SD card E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the of your SD card (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
