Computers & Internet Logo
josh shoemaker Posted on Nov 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can burn one cd or dvd then an error message pops up
If i want to burn more than one cd or dvd i have to restart my computer
Jitha GJ
Level 2:
Novelist:
  • Acer Expert 239 Answers
  • Posted on Nov 20, 2011
Jitha GJ
Acer Expert
Level 2:
Novelist:
Answers
239
Questions
0
Helped
50327
Points
371
I understand that you want burn more than one CD or DVD but unable to do so and have to restart the computer.
It may happen due to the age of the computer or CCD/DVD ROM. When you burn CD/DVD the lens on it become hot, so sometimes it may become unstable and need a restart. It also depend upon the setting of the software also, as it might have set it restart mode after the CD is burned. In this case, I would recommend you to check the setting of the burning software for an option which says "Restart after burning is completed".
Thanks and regards,
Jitha
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
When I attempt to burn a CD from my Windows Media Library or from a a site online, it records maybe 4 seconds before the message pops up that says it cannot complete the task and to check CD for dirtiness...
uninstalled the hardware to the my computer properties & restart the system go back to my computer properties go to hardware click and click device manager
right click the my computer
click the scan my hardware change
and that's all
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Existing CD recorder drive now not working after installed DVD RW
You are to clean registry manually now. Nero still has leftovers in there.
Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is...
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
7helpful
2answers
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
2helpful
Slimline DVD Burner
Go to the device manager. uninstall the dvd drive .restart computer after turning the power off. re-install the device from add hardware wizard.restart computer.this may solve the problem.
1helpful
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
