SOURCE: panasonic SR-LA10N two lamps flash
here is the link for the user manual if you need it http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=SR-LA10N&modelNo=SR-LA10N&storeId=15001&catalogId=11017&itemId=65851&displayServiceCenter=true# I think you may possibly cure this by pressing and holding start as you plug the unit in. also try pressing start and timer together when plugging in. If this doesn't help then unfortunately; Panasonic recommend that the unit needs to be serviced - you can contact them on 1-800-211-7262 for more details or online at http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportContact?storeId=15001#email I hope this helps :)
SOURCE: Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
After extensive web search, this seems to be the only Website listing Panasonic parts:
http://www.partstore.com
SOURCE: my rice cooker, its not responding. Panasonic SR
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
Testimonial: "thanks man..."
SOURCE: Is there any place to buy replacement insert pan
I am looking for the same thing. I was able to dig in Panasonic's parts site, and come up with part number ARE50A805 for the 10-cup pan for this rice cooker.
Unfortunately, so far I have not been able to find anywhere that actually has one; several listings, many of which go back to partstore.com, but then partstore or another site I've seen referred to are not accessible.
